Home Forums Products Eurorack Modules Eventide Device Manager: not finding connected MISHA(s) Reply To: Eventide Device Manager: not finding connected MISHA(s)
#171202
samchillian
    Hello-
    Thanks for doing that test.
    What you say about the USB port sounds increasingly likely to be true, unfortunately.
    But just to be ultra rigorous about this:
    Exactly what cable did you get?  It connects a usb keyboard to the Misha usb Jack, yes?  So it’s female USB-A to micro usb male, is that right?
    What I am using is a “gender changer” adapter usb-a female to female, together with the supplied male usb-a to micro usb male cable.  If you are also using a gender changer together with the supplied cable, it could yet be that the supplied cable is the problem
    But you mentioned a cable, not an adapter, so probably your analysis is right
    Off-hand I don’t know whether num lock should do anything when plugged into Misha, but by default, there ought to be a defined usb keyboard  map (setup/system/usb mapping), and then for example D is set to step 1, so pressing that should move you through the scale . Maybe double check that some keys like “D” are defined, and verify that they’re not working when you press them
    Thanks
