Reply To: H90 4CM Routing Question
Home Forums Products Stompboxes H90 4CM Routing Question Reply To: H90 4CM Routing Question
#171212
sheeny
<p style=”text-align: left;”>Thank you. Is this using the Four cable method?  I.e. one out to the input of the amp, and one out to the effects loop of the amp, meaning can I assign two effects in this case to either pre or post using this cabling configuration?</p>
Thanks for responding!
