Home Forums Products Stompboxes H90 4CM Routing Question Reply To: H90 4CM Routing Question
#171214
joecozzi
    Yes, that is correct. If you look at the H90 manual online you can see we recommend the global dual routing mode for PRE/POST 4CM connections. This gives you two paths – Pre and Post. You can choose where the algorithms go on a Program basis.
