Home Forums Products Eurorack Modules How do you setup Misha to follow a 1v/oct CV input? Reply To: How do you setup Misha to follow a 1v/oct CV input?
#171241
scobot1
    Update:
    So it’s always a bit embarring when you post a question (out of frustration) and then…kind of figure it out. Not that I have completely figured it out, and certainly open to input and suggestions, so please share any tips/tricks/insights you might have. I’ll leave this thread open in case it helps others.
    What I discovered (user error on me) was I had to expand the range of the Melodicer (there is a range setting) and once I did this (out of desperation) BINGO! Misha started to play notes up and down the Misha scale. Sounds great playing DecentSampler piano now.
    How things are set in MISHA:
    • CV in X
    • Range 0->+5V
    • Linking (Linked (Trigger))
    • CV Function: Translate
    • T/G Active State: Normal
    • Tigger Function: Interval Keys
    • Trigger Mapping (default settings I assume) 1-11
      • Move
      • Pitch
      • -5 to 5
    Still would like to read the “comprehensive list of functions” if anyone can find that.
    Thanks again.
