Reply To: H90 – delay tap tempo artifacts
Home Forums Products Stompboxes H90 – delay tap tempo artifacts Reply To: H90 – delay tap tempo artifacts
#171243
Yes, there is.  You have to select the right algorithm.  Some are are programmed to emulate ‘pitch’ / speed effects in classic gear: tape delay, as one example.
Others have a short crossfade between the changing delay times.  The Digital Delay & Reverse algorithms ‘expose’ that parameter, so you can adjust just how long that crossfade takes (within a range).
