Home Forums Products Stompboxes Recalling Presets with Aux Switches Reply To: Recalling Presets with Aux Switches
#171291
joecozzi
    Hi peaceonu,
    I wonder if it is possible to increase the number of presets in bank mode from the current 3 to 5 and call the increased 2 presets with the Aux switch.
    Let’s assume this was possible. At minimum, you’re asking for two more switches. There currently exists a few options that would give you access to more programs:
    1. While in Bank mode, hold down the B footswitch. This will shift over to the next Bank where you can find another set of three Programs. Holding down A goes down a bank. Holding down P goes back to Bank 1.
    2. Map Bank Up and Bank down commands to an external 2 or 3-button aux switch. Doing so instantly banks without waiting an extra second the way holding down A or B does. You can more freely navigate through banks of three.
