Reply To: H90 Tuner-How to set where it mutes
Home Forums Products Stompboxes H90 Tuner-How to set where it mutes Reply To: H90 Tuner-How to set where it mutes
#171315
Can you be more specific about what you are expecting to happen? I’ve just tested a few scenarios with DSP and Relay Bypass and it seems that the tuner is correctly muting or not muting depending on the setting in the tuner menu. The tuner menu’s mute/thru setting will be applied regardless of the Program bypass/active setting.
