Home Forums Products Stompboxes Can H90 hardware do USB interface Reply To: Can H90 hardware do USB interface
#171360
joecozzi
    Care to elaborate on your choice of dual routing? I thought I had mine setup the most efficient way but maybe I’m mistaken. What advantages does that give over insert?
    I chose Dual Routing Mode for the simplicity of setting up a PRE/POST rig. I commend you on figuring out PRE/POST with Insert Routing mode. It’s actually my preferred signal flow with a mono amp; however, troubleshooting becomes bit more difficult considering any one cable goes bad and the entire signal chain is broken, highly unlikely in a properly wired board.
