Home Forums Products Stompboxes h90 latency on inserts Reply To: h90 latency on inserts
#171385
nico___
    i have tested the same program with the algos in  bypass and the latency persist, than without algo in utility thru and it work pefectly with no latency(only insert2), in the end i have tested 1 algo in thru and the other algo with simple digital delay and the latency decreased, almost halved.
    it is as if the algorithms have a latency weight in the activation.
    p.s i used Upload Attachments for the program but i don’t if it works.
