Home Forums Products Stompboxes H90 Volume Bump When Bypassed Reply To: H90 Volume Bump When Bypassed
#171387
joecozzi
    This does not sound like normal operation. Try putting two THRU utility algorithms on a Program. When you bypass the H90, there should not be any apparent drop or increase in volume. If you do experience that, I recommend conducting a factory reset. Before you do, back up your Programs to a list and record any system settings.
