Home › Forums › Products › Rackmount › H9000 Feature Request: Larger Note Display › Reply To: H9000 Feature Request: Larger Note Display
May 25, 2023 at 3:22 pm
#171540
I would suggest to make the note as large as possible while still fitting within the box. Here’s an image showing what I mean:
The error cnts could be a bit bigger as well. Maybe it could use the same top/bottom layout that the note uses. “Error” on top and the cnts below with a font size increase (doesn’t need to be as big as the note)
