Home › Forums › Products › Rackmount › Logic USB via Emote as AU (No signal passing through) › Reply To: Logic USB via Emote as AU (No signal passing through)
#171581
pinballmagnetic
    Yes, this might be it. I do get proper ins and out signals when i select the h9000 as audio interface in Logic.
    The question is how do i route the  outputs from the Emote software to the right channels?
    I need a little help, the io settings are a bit confusing to me. I’m learning 😉
    Thanks
