Home › Forums › Products › Rackmount › Logic USB via Emote as AU (No signal passing through) › Reply To: Logic USB via Emote as AU (No signal passing through)
#171585
    This looks like you have the H9000 USB audio driver as your input/output device in Logic. You need to create an aggregate device with your audio interface, and then select that aggregate device as the input/output device in Logic.
    0/2.0/content/setup/usbsetup.html#using-the-h9000-with-macos
