Home › Forums › Products › Rackmount › Logic USB via Emote as AU (No signal passing through) › Reply To: Logic USB via Emote as AU (No signal passing through)
May 27, 2023 at 5:39 pm
#171588
Thank you: With the “Reverb Busses” i can get signal to and from the DAW to the h9k (those are some amazing reverbs btw).
Here an overview:
The aggregated device view shows the outputs that should correspond with the IO settings in the H9k
The overview of the emote settings shows the in and out signal i can get from the IO utility.
But for some reason the Emote AU doesn’t process the audio without the IO-utility.
How should i configure the IO settings?
