Home › Forums › Products › Rackmount › Logic USB via Emote as AU (No signal passing through) › Reply To: Logic USB via Emote as AU (No signal passing through)
May 27, 2023 at 8:15 pm
#171600
You’re going in circles. Put the aggregate back to how you had it (audio interface first). Adjust the I/O plug-in to output and input to the correct AGGREGATE channel numbers and you’re good to go. You’re making it hard to figure out what you’re trying cause I still didn’t see a screenshot of Logic yet (get emote out of the way). And also show your settings for the I/O plug-in as well please.
