Home Forums Products Rackmount Logic USB via Emote as AU (No signal passing through) Reply To: Logic USB via Emote as AU (No signal passing through)
#171611
pinballmagnetic
    I got everything hooked up now with all the routing hardwired in my Logic template. Turned out I didn’t fully understand the functionalities of the Emote software. It will be all over my next EP, it sounds truly amazing. I even connected my H3000 with the H9000 and use it as a source for further processing.
