Home › Forums › Products › Rackmount › CC from Max to Emote › Reply To: CC from Max to Emote
May 29, 2023 at 11:00 pm
#171616
It’s been a while since I’ve programmed in Max, but from looking over an old program I made, make sure that you pak controller number and then the controller value and send that to the third input port of a midiformat. I suspect you are wired into the first port of midiformat.
Wire your midiout to the first output of midiformat
