Home Forums Products Stompboxes H90 questions Reply To: H90 questions
#171699
Hermetech
    You can use Relay Bypass for a pure analogue signal while the H90 is bypassed, but the dry signal will always go through the ADC/DAC convertors.
    Thanks, exactly the same as the H9 then. 🙁 Any reason why there couldn’t be an option in future to allow true analogue for the Dry signal? I guess the only way to do it would be with some extra routing box for the pedal board.
