Home Forums Products Stompboxes Can’t hear certain patches from H90 with Quad Cortex Reply To: Can’t hear certain patches from H90 with Quad Cortex
#171730
    Are you only using I/O 1&2 on the H90? Is so, then you’d be better off using Insert Routing.
    When using Dual Routing, press the Routing button and you can visually see which algorithms are on which path. By default, they should all be on path 1 (I/O 1-2) but perhaps some of them have been moved to the other path and that’s why you aren’t hearing the effects.
    If you are still having issues, please let me know the specific Programs you are having issues with and make sure the routing is correct.
