Home Forums Products Rackmount What could be the cause of intermittent drops in the audio connection? Reply To: What could be the cause of intermittent drops in the audio connection?
#171748
pinballmagnetic
    Thanks for jumping in:
    – I can’t find any consistency in this. Rebooting the h9k, relaunching the daw, select different sample rate and than back, i’ve tried all in different order and combinations but i can’t find a consistent way of solving this issue. Rebooting the h9k seems to help, but only after altering the sample rate in my DAW, reselect the aggregate device and connect the H9k again. Sometimes i also need to reconnect the h9k.
    Again, i can’t find a consistent solution that makes sure i can keep the audio signals from my daw in to the H9k.
    – The “USB Audio Mute” error does not pop up when the audio drops, i do however regularly get the message that the network connection is lost with the h9k from the emote app.
    -I’ll try loading algorithm 13 to see what happens and report back.
    I’m afraid there are multiple problems at once i need to isolate first before working to a solution.
