Home Forums Products Rackmount What could be the cause of intermittent drops in the audio connection? Reply To: What could be the cause of intermittent drops in the audio connection?
#171825
    Doesn’t sound like the same issue if you are using ADAT and not USB.
    When using ADAT, both devices need to share the same clock source to sync the clocks together. You can either set the H9000 clock to ADAT to sync the H9000 to the RME, or Sync the RME to the H9000 and use the H9000 internal clock.
