Home › Forums › Products › Rackmount › 9000 update issue › Reply To: 9000 update issue
#171933
zhoozha
    hi!
    1. issue with midi:
    i’ve got h9000r. the device was connected by ethernet. i use macos big sur.
    this simple event with controller changes in cubase 12 pro was worked perfectly with old firmware.
    after i have updated firmware this event stopped working.
    2. issue with frequency shift:
    try my simple algo and watch the level of channel with frequency shifter drops significantly within 10-15 minutes. this makes it impossible to work with long projects using this algorithm.
