Home Forums Products Rackmount Mapping MIDI controller to parameters Reply To: Mapping MIDI controller to parameters
#171949
    First, what controller are you using and how is it connected to the H9k?
    When you say “For some reason Emote sees this as a program change message on channel 2” what do you mean? Are you using Learn and it shows the incorrect MIDI data in Emote?
    Can you try using a MIDI monitor from your controller to make sure it isn’t sending the unwanted MIDI data?
