Home Forums Products Rackmount Mapping MIDI controller to parameters Reply To: Mapping MIDI controller to parameters
#171960
klango
    Thank you for your reply.
    It’s a fader on keyboard that is connected to the MIDI in of the H9000R.
    The fader sends controller data on controller #21 channel 1, as I verified on a Midi monitor.
    I’m mapping by putting a parameter in learn mode, moving the fader and apparently the incoming data is seen as program change on MIDI channel 2.
    The same happens when I send controller data from MAX.
