Home Forums Products Stompboxes H90 questions Reply To: H90 questions
#171972
teabandito
    Hello, I have a couple questions about my H90:
    1. Adjusting the program’s bpm in the H90 Control – is it ever possible? Where can I find it?
    2. Can I just type in the desired numbers in all the program parameters in the H90 Control? In the H9 Control I was able to just do the double tap at the parameter and type in the needed number. In the H90 Control it does not react on double tap like this so I have to scroll through the numbers until the one I need.
    3. Is it possible to assign effect bypass to expression pedal position? To turn it on in toe position and turn off in heel position? If not, let it be a feature request 🙂
