Home Forums Products Stompboxes H90 questions Reply To: H90 questions
#171981
teabandito
    Thank you for your help!
    1. Yes, click the System tab to find the Tempo Menu.
    Is the tempo in the System tab specific for the program? Looks like it’s for the whole preset (both programs in the preset) if not the global at all?
    And why can’t I tap at the number to type in the needed tempo?
    2. Yes, using the latest version of H90 Control you can type in parameter values. Only a single click on the field is necessary.
    Works great indeed, thanks for that ๐Ÿ™‚ Now would be great if I all the numbers could dialed like this in the H90 Control. Tempo Menu in System tab for example ๐Ÿ™‚
    3. Yes, but only using H90 Control. Click the Presetโ€™s General tab and then click the mapping arrow on the active/bypass parameter.
    Cool, works like a charm, thank you! ๐Ÿ™‚
