Home Forums Products Rackmount Any use trying the H9000 for summing? Reply To: Any use trying the H9000 for summing?
#172015
Puppeteer
    I’ve fixed the bypass issue and also fixed an issue with the panning being reversed.  The gain controls are now in percent rather than dB, which will give better control around the top end.  While the knob display’s values to the nearest percent, you can type in decimals if you need finer control.
    You can download this at the same link as before at https://www.buymeacoffee.com/godlikeprod/e/143383, and it’s also in the message section for subscribers.
    If you have previously downloaded this, please delete the old version from your H9000 and load this one instead.
