Home Forums Products Stompboxes Saving in H90 Control Reply To: Saving in H90 Control
#172146
cscotto
    Hi, Thanks for the reply. While I do have a controller, it is not receiving any external control data. I removed the controller, and had the H90 connected to the computer via USB.
    I did find one thing. Does not matter whether I paste the program or load it from the program list, the asterisk appears. However, if I use the save icon at the bottom of the list window the save function works as it should. If I use the save button in the upper right hand corner, then the odd behavior appears.
    Nevertheless, if I edit a parameter, and use either the save button at the bottom of the list window or the save button in the upper right hand corner, the behavior I mentioned above persists.
    Finally, I am connecting the H90 to an Intel Mac mini. I thought I would connect it to my M2 Max Mac Studio to see if the same behavior persists. I can’t get H90 Control app to recognize the H90, its connect button is grayed out. However, I know the computer see the H90 because if I go into system reports and check the USB connected devices, the H90 appears.
