Home Forums Products Stompboxes H90 Dual Mode or Insert Mode? How are you connecting to your amp/amp pedal? Reply To: H90 Dual Mode or Insert Mode? How are you connecting to your amp/amp pedal?
#172163
joecozzi
    Hi joaters,
    In addition to what you mentioned, another benefit to running your ToneX in Insert global routing mode is the ability to use the second insert loop of the H90 for another effect you can place anywhere in the chain. The main thing to be aware of when using an insert loop for an amp is that when you bypass a Program you’ll also be bypassing the loop that the amp is connected to inadvertently breaking the signal chain.
