Home › Forums › Products › Stompboxes › H90 DynaFlanger(s) Program › Reply To: H90 DynaFlanger(s) Program
        June 28, 2023 at 9:24 am
        #172203
Sounds like some good advice, all around. Concise, with an extra helping of option paralysis.
Now I’m going to toss a giant wrinkle into your list of possibilities and overall process:
- The Quad Cortex is upstream, I assume.
 - H90 Insert Mode – using Input / Output 1 & 2.
 - Dry input centered and accessed at the Program level.
 - The original MicMix DynaFlanger Pair Program (as programmed, in parallel) – each Preset stereo to both outputs.
 - Meris PolyMoon as a stereo insert – H90 Input / Output 3 & 4.
 - PolyMoon programming & insert placement in the H90 – your choice for best results.
 - Modify everything (IF needed), for wah, distortion, dynamic flanger, phasers – best sounding combination.
