Home › Forums › Products › Rackmount › Sidechain Vocals to Reverb in H9000? › Reply To: Sidechain Vocals to Reverb in H9000?
June 28, 2023 at 11:44 pm
#172221
You could build a chain with a compressor feeding a reverb in the H9000, the same way. Just use a third buss input as the side chain.
Alternatively I built a dynamic send algorithm that can send to different algorithms depending on the signal level.
https://godlike.com.au/index.php?id=420
I could modify it to have an external side chain pretty easily, if you think it would be useful.
