Home Forums Products Stompboxes Rose – external controller advice Reply To: Rose – external controller advice
#172238
rck
    You’re welcome. 2. No, it will not automatically be mapped. In this configuration, the expression pedal will be outputting a MIDI CC from the MIDI controller. On the Rose, you can decide which CC# (1-31) will control the morph. It will depend on which MIDI controller you choose, but you’ll need to configure this to output the correct MIDI CC.
    Can the Rose’s Delay Mix parameter be accessed/controlled via MIDI Expression controller?
    Basically, I would like to access the Rose’s Delay Mix via an Expression pedal. Is there someway to do so?
    Thank you.
