Home Forums Products Stompboxes Noise when using 4cm/Dual Routing Reply To: Noise when using 4cm/Dual Routing
#172270
joecozzi
    Can you give us a clear understanding of your signal flow? Are you using Insert or Dual Mode to connect 4CM? What are your operating levels on H90’s I/O? What Bypass Mode are you using on the H90?
