Home Forums Products Stompboxes H90 – EQ Compressor Issue Reply To: H90 – EQ Compressor Issue
#172323
Infection
If you turn the gain on the channel up, you are increasing the volume into the H90, and the compressor will counteract this by further reducing the volume as the input gets louder.
You are fighting the compressor.
Either turn up the trim knob in the compressor (will add volume after the compression), set the compressor knob closer to 0 (less gain reduction), or both.
