Home Forums Products Plug-Ins Split EQ .5 sec latency on M1 Reply To: Split EQ .5 sec latency on M1
#172407
    Sorry you are having issues. How are you bypassing the plug-in? Are you using Logic’s native bypass or the bypass in the SplitEQ UI?
    In Logic, can you confirm that you have delay compensation set to “all” and you do not have “low latency” turned on?
