Home Forums Products Stompboxes H9 volume is always at “0” ? Reply To: H9 volume is always at “0” ?
#172545
    Does the issue only happen with an expression pedal connected? Do your presets load with the correct value if the expression pedal isn’t connected?
    Are you able to test this with a different pedal/cable?
