Home › Forums › Products › Stompboxes › Is it possible to use inserts in Dual mode › Reply To: Is it possible to use inserts in Dual mode
#172619
rxguitars
    My 4CM setup is basic:
    H90 set on Dual Mode
    Guitar into 2 fuzz pedals, Wah , OD and then into input 1 of the H90
    Output 1 of H90 to the input of my Amp
    Amp send to Input 3 of H90
    H90 output 3 to a always on reverb then to the return of my Amp
    I’m fine with being more mindful of set up and routing. Can you explain how achieve using 4CM in insert mode ? .
    How would I be able to send half of a program to the amp send/ return ?
    Roy
