Home › Forums › Products › Stompboxes › Wish list from users for future updates of the H90 › Reply To: Wish list from users for future updates of the H90
You can rename lists by clicking the pencil icon in the bottom left corner of H90 Control. It is not possible to rename lists using just the pedal.
It sounds like you also have the mix control mapped to the HotSwitch. You can use the Select knob to scroll through all of the parameters while you are mapping a HotSwitch, then press a Quick Knob to map or unmap the parameter to the HotSwitch. Using H90 Control also makes it a bit easier to see all the parameters that are mapped to a HotSwitch in one place.
We’re working on some video tutorials, thanks for your patience. Let me know if there is anything else I can help with in the meantime.
