Home Forums Products Stompboxes H90 Inserts – I’m Using [Fill In The Blanks] Reply To: H90 Inserts – I’m Using [Fill In The Blanks]
#172804
vaisatchatrucci
Thanks so much for that info! I have thrown a couple things in the insert loop at this point but ultimately was wanting to use my Eventide Eclipse in there and hoping to be able to assign an expression pedal via the H90 to control the insert mix level and also be able to control the position of the Eclipse as well routing wise but you confirmed the latter cannot be done but how about controlling the mix level of the insert via midi is that possible?  My apologies as well if I should move this to a different thread / post just let me know!  Thanks so much again in advance!
