Home › Forums › Products › Stompboxes › Wish list from users for future updates of the H90 › Reply To: Wish list from users for future updates of the H90
… May I go to bat for PAN CONTROL! Even if just for the phasers. The best part of a Bi-phase is two slow phasers sweeping in stereo parallel at slightly different rates …
I’m with you on the Pan control; probably at the Program level with Parallel routings. In Series, you can pull off Balance-type.control.
I just wanted to add that you can currently pull off that Phaser trick. I just uploaded something virtually identical, except with 2 Chorus instances in parallel.
It’s a little more work, but I’ve gone down the rabbit hole lately, using the (P)rogram HotKnob as a blender between parallel effects. Simple, but versatile.
