Home Forums Products Stompboxes H90 High Pitched Noise Reply To: H90 High Pitched Noise
#173076
joecozzi
    I’m confused. In your original post you said the noise is there “Even when not connected via USB.” USB noise, unfortunately, is normal and indicative of some sort of grounding loop in your system. There’s no way to get rid of it except for disconnecting the USB cable when you’re using the H90.
