Home Forums Products Rackmount Dante card, ethernet cable connections Reply To: Dante card, ethernet cable connections
#173124
    You’re welcome.
    If you are still using the UFX with ADAT, I would suggest having the UFX be the clock source for everything like so: UFX > H9000 > Dante card
    To do this, set the H9000’s clock source to ADAT, and then in Dante controller check off the “Enable Sync to External” box for the EVT-H9k device. This setting enables the Dante card to sync to the H9000’s clock.
    Note that in Dante Controller, you may also have to manually set the sample rate, even if it is externally synced. Double click the EVT-H9k device, click the “Device Config” tab, and set the sample rate there.
    Let me know if that works.
