Home › Forums › Products › Stompboxes › H90 New Preset – how to? › Reply To: H90 New Preset – how to?
August 16, 2023 at 8:35 am
#173189
Something to look out for, that I discovered last night:
- The 000TB DynaVerb Program contains the base parameter settings as intended.
- When I loaded up the 000 DynaVerb Preset (saved as above), all of the parameters were reset CCW.
- I believe that the 000 UltraTap Preset may also reset (at least) the MIX to 0.
- There may / may not be a few others, that – at the time – I chalked up as an errant adjustment.
The workaround for now would be to build around these few Programs, or be mindful of the behavior with these two Presets.
