Home › Forums › Products › Stompboxes › Setting panning stereo repeats on h90 delays › Reply To: Setting panning stereo repeats on h90 delays
I think your stumbling block on those Presets is in the Delay Mix. You want it centered A10+B10, to affect both delays equally. Then there’s the offsets you need in the two Delay times, to get them panning.
I did a quick mod on those 2 Presets; getting rid of the extraneous values. If you want the shorter & longer Delays to fade out at about the same rate, it’s important to adjust the Feedback levels accordingly.
I want to add the Feedback routing is different across many of the Delay / Pitch / Multi algorithms. At times it will be a single Feedback path for both Delays, or cross-feedback, twin Delay Feedback paths, Feedback path mixed to mono, ‘disintegrating’ Feedback, or the Feedback length equal to the longest Delay time.
The point being: That offers a lot of options, but be aware that the panning results will be very different, depending on the algorithm used.
