Home › Forums › Products › Stompboxes › Setting panning stereo repeats on h90 delays › Reply To: Setting panning stereo repeats on h90 delays
August 19, 2023 at 4:35 pm
#173479
Thanks Brock!
I can hear the panning delays, or going stereo back-and–forth motion of the echos, as I set each delay on a different time signature, 1/4 and 1/8. And that alone sounds super-cool! I was hoping to create an echo that has the same beat division that bounces from left side to right side as the echos fade, being able to control the amount of signal into the non-dominant side with each passing echo. Is there a algorithm that you are aware of on the unit that does that, with minimal modulation? I will check out other algorithms to see if I can find that!
