Home › Forums › Products › Stompboxes › Setting panning stereo repeats on h90 delays › Reply To: Setting panning stereo repeats on h90 delays
August 19, 2023 at 10:52 pm
#173483
You know, sometimes you just can’t see the forest for the trees. I’ve been working all evening with UltraTap. Perhaps my favorite – a multi-algorithm if there ever was one. And yet, it just dawned on me that this is a near-perfect fit for your application.
A single beat division, with ping-pong panning, using a single Feedback control.
- The Length is going to be ping + pong.
- That is, instead of thinking of it as a 1/4 note ping-pong delay, consider that the total L+R Length will be 1/4 note + 1/4 note.
- The Length (1/2 note above) is divided by the number of Taps (2 here).
- The Width of 100 pans those two Taps full right & left.
- For left to right, change the Width to -100.
- The single Feedback control loops around the entire Length.
You’ll have fun later on with all those other parameters (set to neutral / minimized values here).
