Home Forums Products Stompboxes Is it possible to use inserts in Dual mode Reply To: Is it possible to use inserts in Dual mode
#173486
unconsiglio
    Good afternoon tbskoglund and staff,
    I tried this specific routing (insert mode) with a 4 cable method layout: unfortunately I incurred in a major issue.
    Regardless of the on/off status of the insert 1 block, there is always signal present at Out 1 (and therefore at the amp return…). Amongst the consequences, even a low increment of gain at the input of the chain, like a compressor between guitar and H90, produces a mild saturation in the amp.
    On a related note, how should the insert 1 mix be set with such configuration?
    Could you kindly help?
