Home Forums Products Stompboxes H9 output level control Reply To: H9 output level control
#173602
LouRossi
    It has been 7-years and apparently this has not been addressed? I have a song where I am using the PitchFuzz algo. I have a 460mS delay that is prominent, I need to be able to use this delay both with and without the fuzz. Setting the FUZZ parameter to go from 0 (toe up) to 39 (toe down) gives me way too much volume when the fuzz is dialed up. I’d like to be able to push the OUT LEVEL down a a bit as the toe moves downward. Is there any chance this feature can be added? If the blue line that is seen on the other parameters could be added alongside the OUT LEVEL Fader, so that the start and stop end points as well as polarity swap can be programmed, that would be awesome.
    Many thanks,
    Lou
