Home Forums Products Stompboxes H90-Reverse w/ min X-fade = … ring mod-ish?~?~ Reply To: H90-Reverse w/ min X-fade = … ring mod-ish?~?~
#173606
    X-Fade is quite the mini-rabbit hole, isn’t it?  I suppose the atonality might not be for everyone, but I really enjoyed this.
    Metallic funk, using real metals.  I had to laugh at the use of the Keaton clips.  Matched up almost perfectly as a soundtrack.
    Nicely done, Mitch.  See, the catch is … now you have to share those H90 Presets / Programs you used.
