Home Forums Products Stompboxes Weird changing trails between presets (With delay) Reply To: Weird changing trails between presets (With delay)
#173901
    If you can provide the specific algorithm (or algorithms) you’re using, that would help a lot in diagnosing.  The actual Presets used might be even better.
    I’m guessing that the apparent ‘pitch’ of the delays are changing?   It might just boil down to switching to a delay type that crossfades between delay times.
    Again, these will only be guesses without some more information.
